1 7 7
  1. #1
    Kubuntu
    KDE
    Apr 2009
    9
    0
    Ubuntu
    Creative VF0330
    Genius
    http://www.linuxac.org/forum/linuxac8/thread9380.html
    Skype
  2. #2
    Mint 8
    GNOME
    Oct 2007
    205
    118
    226 68
    usb2 usb1
    A computer is Like Air conditioning,
    It's works Fine until You open....... Windows.
    Android Arab Community
  3. :
  4. #3
    Kubuntu
    KDE
    Apr 2009
    9
    0
    usb2 usb1
    usb2
  5. #4
      alsadi
    Fedora 20
    GNOME
    Feb 2008
    8,381
    511
    12,897 2,766
    3
    em8300
    qc-usb
    gspca
  6. alsadi :
  7. #5
      Ahmed radwan
    Slackware 13.1
    KDE
    Jun 2008
    745
    456
    464 186
    PHP:
    lsusb
    PHP:
    sudo apt-get install cheese
  8. #6
    Kubuntu
    KDE
    Apr 2009
    9
    0
    em8300
    qc-usb
    gspca
    Bus 001 Device 003: ID 0457:0151 Silicon Integrated Systems Corp. Super Flash 1GB / GXT 64MB Flash Drive
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 002 Device 002: ID 041e:405f Creative Technology, Ltd
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  9. #7
    Fedora 11
    KDE
    Jan 2010
    1
    0
    Solution tested on fedora11
    Hello,
    I am sorry for writing this answer in english.
    I solved that problem on my fedora 11 box, if it is not the same on kubuntu it wont be so different.
    Well, I have this same webcam and I needed just to add something before typing the command to start skype from the console.
    You need to add this line :
    LD_PRELOAD=/usr/lib/libv4l/v4l1compat.so
    The cause is that this webcam doesn't work with the new V4L2, it works with the old V4L (V4L1)
    What does this cause? it causes that some applications wont support it (like skype, even if it works on cheese) and the solution is to add the ligne provided above as a prefix to the command starting the program like this :
    LD_PRELOAD=/usr/lib/libv4l/v4l1compat.so skype
    for sure you do not want to start skype all the time from the terminal. So here is what you can do in KDE :
    Right click on Kmenu
    Menu editor
    go to Internet>Skype
    change the command from
    skype
    to
    Done, now you can start it from the menu with no problems.
    if you do not have the file /usr/lib/libv4l/v4l1compat.so you can install it as root on fedora using
    yum install libv4l libv4l-devel
    and on ubuntu using
    apt-get install libv4l libv4l-devel
    Sorry again for writing the answer in english. If LD_PRELOAD doesn't work the same on kubuntu or if you cannot solve it, provide me with exact version of your kubuntu and so I can help you with more specific details.
    Good luck.
  10. Neo31 :
: 1 (0 1 )
  1. : 10
    : 04-09-2011, 04:27 AM
  2. [] vga
    Benoumhani .: :.
    : 1
    : 03-01-2010, 11:05 AM
  3. []
    cobra2000 .: () :.
    : 0
    : 22-05-2009, 01:05 PM
  4. [] genius
    : 7
    : 06-05-2008, 09:56 PM
  5. Ati
    : 1
    : 23-04-2008, 10:05 PM
