1 2 2
: zte mf 190 hsupa
  1. #1
      Mummy yow
    Ubuntu 12.04
    Jul 2013
    5
    1
    0 0
    zte mf 190 hsupa
    ١٢.٠٤
    4G
    3G .....
    zte mf 190 hsupa
  2. #2
    Debi Linux
    LXDE
    Oct 2009
    118
    497
    13 9
    ZTE 190S " " "
    Edit connection
    Mobile Broadband
    Add
    Any Continue
    Country region Continue
    Provider Continue
    Continue
    Apply
    This software will not run until you install "QT3 Runtime Library". You can refer to Operaing System installation CD or Homepage to find out the QT3 Runtime Library installation package. This installation process will not continue until you install QT3 Runtime Library first.
    install.sh
    #! /bin/bash
    FILE_NAME=Etisalat_USB_Modem
    EXE_FILE=Etisalat_USB_Modem
    DISPLAY_NAME="Etisalat USB Modem"
    SYS_PATH=/opt
    INSTALL_PATH=$SYS_PATH/$FILE_NAME
    LANGUAGE=English
    QM_NAME=ondatim_lan.qm
    HELP=help
    RUN_EVINCE=$SYS_PATH/$FILE_NAME/Data/launchFirefox.sh
    UPDATE_FILE=update
    APLAY=$SYS_PATH/$FILE_NAME/Data/aplay.sh
    #Define variable-two-phrase-production---begin---------
    TWO_ON=true   # true or false
    PATH_NAME=`dirname $0`
    TMP_DIR_NAME=/tmp
    TWO_FRASE_TEMP_DIR=$TMP_DIR_NAME/two_phase_temp
    TWO_FRASE_CONFIG_FILE_MODEM=/PCCFG/Description.xml
    DES_DIR=$INSTALL_PATH
    ZIP_FILE_NAME=$TWO_FRASE_TEMP_DIR/lu.zip
    TEMP_DIR=$TWO_FRASE_TEMP_DIR/temp
    LAST_RUN=$INSTALL_PATH/last_run.sh
    CHOOSE_LANGUAGE_RUN=$TEMP_DIR/choose_language.sh
    #Define variable-two-phrase-production---end------------
    # function defination begin
    function get_distro_name {
        ISSUE_NAME="/etc/issue"
        DIS_NAME="other"
        if [ -e $ISSUE_NAME -a -f $ISSUE_NAME ]; then
            if [ "$(grep "Ubuntu" $ISSUE_NAME)" ]; then
                DIS_NAME="Ubuntu"
            elif [ "$(grep 'SUSE' $ISSUE_NAME)" ]; then
                DIS_NAME="OpenSUSE"
            elif [ "$(grep "Fedora" $ISSUE_NAME)" ]; then
                DIS_NAME="Fedora"
            elif [ "$(grep "Mandriva" $ISSUE_NAME)" ]; then
                DIS_NAME="Mandriva"
            fi
        fi
        echo $DIS_NAME
    function assert_software_installed
        if [ -f $INSTALL_PATH/$FILE_NAME ]; then
            echo "****** Fail to install !!! "
            echo the "$FILE_NAME" has been installed.
            read -p "press any key to exit.... " -n 1
            exit -1
        fi
    function assert_root_privilege
        echo -n "*** Check for root..."
        if [ $EUID -ne 0 ]; then
            echo -e "\b\b\b - failed"
            echo "*** Please retry as root user."
            exit -1
        fi
    function mymessagebox
        MSG_CMD_GNOME="/usr/bin/zenity"
        MSG_CMD_KDE="kdialog"
        if [  -e $MSG_CMD_GNOME -a -f $MSG_CMD_GNOME ];then
            $MSG_CMD_GNOME --error --title="$1" --text="$2" 2>/dev/null
        else
            $MSG_CMD_KDE --error "$2" 2>/dev/null
        fi
        echo -e "\n$2\n"
        read temp
    function check_wvdial
        WVDIAL="/usr/bin/wvdial"
        if [ -e $WVDIAL -a -f $WVDIAL ];then
            echo "check wvdial successfully."
        else
            mymessagebox "Sorry" "This software depends on \"wvdial\" to establish internet connection. You should install \"wvdial\" first.You can refer to Operating System installation CD or Homepage to find the \"wvdial\" installation package. This installation process will not continue until you install \"wvdial\"."
        exit -1
        fi
    function check_qt3
        QT3LIB=$(find /usr/lib -name "libqt-mt.so*")
        echo $QT3LIB
        if [ "$QT3LIB" ];then
            echo "check QT3 Runtime Library successfully."
        else
        mymessagebox "Sorry" "This software will not run until you install \"QT3 Runtime Library\". You can refer to Operaing System installation CD or Homepage to find out the QT3 Runtime Library installation package. This installation process will not continue until you install QT3 Runtime Library first."
            exit -1
        fi
    function select_language
        echo >/dev/null
        #Select the language for the installation form the choices below.
        #      (1) English
        #      (2) Italian
        #      (3) Spanish
        #      (4) Simplified Chinese
        #      (5) Traditional Chinese "
        #echo "Please input number (1,2,3,4 or 5):"
        #read S_NUMBER
        #if [ $S_NUMBER == "1" ];then
        #   LANGUAGE=English
        #elif [ $S_NUMBER == "2" ];then
        #   LANGUAGE=Italian
        #elif [ $S_NUMBER == "3" ];then
        #   LANGUAGE=Spanish
        #elif [ $S_NUMBER == "4" ];then
        #   LANGUAGE=Simplified_Chinese
        #elif [ $S_NUMBER == "5" ];then
        #   LANGUAGE=Traditional_Chinese
        #else
        #   LANGUAGE=English
        #fi
    function two_phrase_production_state1
        rettfp=3
        if [ $TWO_ON == 'true' ];then
            if [ -d $TWO_FRASE_TEMP_DIR ]; then
                    rm -rf $TWO_FRASE_TEMP_DIR
            fi
            mkdir -p $TWO_FRASE_TEMP_DIR
                if [ -f $PATH_NAME/zr ];then
                chmod +x $PATH_NAME/zr
                    $PATH_NAME/zr $TWO_FRASE_CONFIG_FILE_MODEM $TWO_FRASE_TEMP_DIR
                    rettfp=$?
                fi
            if [ $rettfp == '5' -o $rettfp == '6' -o $rettfp == '7' ];then
                    echo -e "Stage 5"
                #   echo -e "Can not complete the installation. Installation will abort."
                #   echo -e "Please try to install again."
                #       read temp_1
                #   exit -1
            elif [  $rettfp == '3'  -o  $rettfp == '4'  ];then
                    echo -e "Stage 3"
            else
                    echo -e "Get resouse file successfully."
            fi
        fi
    function delete_previous_file
        #delete first
        if [ -f $INSTALL_PATH/$FILE_NAME ];then
            rm -rf $INSTALL_PATH
                rm -f /bin/$FILE_NAME
        fi
        if [ -f $INSTALL_PATH/$EXE_FILE ];then
                rm -f /bin/$EXE_FILE
        fi
        TMP_FILE=/etc/defaultwvdial.conf
        if [ -f $TMP_FILE ];then
            rm -f $TMP_FILE
              echo ..........delete $TMP_FILE ok...........
        fi
        TMP_FILE=/etc/ppp/defaultoptions
            rm -f $TMP_FILE
        fi
        TMP_FILE=/etc/ppp/defaultresolv.conf
            rm -f $TMP_FILE
        fi
        TMP_FILE=/etc/defaultresolv.conf
            rm -f $TMP_FILE
        fi
        TMP_FILE=/usr/share/applications/$FILE_NAME*.desktop
            rm -f $TMP_FILE
        fi
        TMP_FILE=/usr/share/pixmaps/$FILE_NAME*.png
            rm -f $TMP_FILE
        fi
        #delete autorun files
        TMP_FILE=/sbin/join-air-launch.sh
            rm -f $TMP_FILE
        fi
        TMP_FILE=/etc/udev/rules.d/998-join-air.rules
            rm -f $TMP_FILE
        fi
        TMP_FILE=/etc/udev/rules.d/9-cdrom.rules
            rm -f $TMP_FILE
        fi
    function extract_installation_package
        cp -f $FILE_NAME.tar.gz $SYS_PATH/$FILE_NAME.tar.gz
        cd $SYS_PATH
        tar -zxvf $FILE_NAME.tar.gz
    function two_phrase_production_state2
        if [ $TWO_ON == 'true' -a $rettfp == '0' ];then
            # unzip files
            unzip > /dev/null
            ret=$?
            if [ $ret != '0' ]; then
                echo -e "Can not find unzip."
                echo -e "Installation will abort."
                exit -1
            fi
            unzip -o $ZIP_FILE_NAME -d $TEMP_DIR
            retunz=$?
            if [ $retunz != '0' ]; then
                echo -e "unzip $ZIP_FILE_NAME failed."
                exit -1
            else
                echo -e "unzip $ZIP_FILE_NAME successfully."
            fi
            RETURN_CHOOSE_LANG=1
            if [ $rettfp == '0' -a -f $CHOOSE_LANGUAGE_RUN ];then
                chmod +x $CHOOSE_LANGUAGE_RUN
                RETURN_CHOOSE_LANG=$?
            fi
            #change permission
            #chmod 0755 -R $TEMP_DIR
            #chmod u+s  -R $TEMP_DIR
            # backup destination directory
            BACKUP_DES_DIR=$TWO_FRASE_TEMP_DIR/backup_for_desDir
            if [ -d $BACKUP_DES_DIR ];then
                rm -rf $BACKUP_DES_DIR
            fi
            mkdir -p $BACKUP_DES_DIR
            cp -rf $DES_DIR/* $BACKUP_DES_DIR/
            #start to replace
            cp -rf $TEMP_DIR/* $DES_DIR/
            retplace=$?
            if [ $retplace != '0' ];then
                cp -rf $BACKUP_DES_DIR/* $DES_DIR/
                echo -e "Replacing file failed."
                exit -1;
            else
                echo -e "Repalcing file successfully."
            fi
        fi
    function setup_menu
        chmod 0755 $INSTALL_PATH/usr/share/applications/$EXE_FILE.desktop
        cp -f $INSTALL_PATH/usr/share/applications/$EXE_FILE.desktop /usr/share/applications/$EXE_FILE.desktop
        chmod 0755 $INSTALL_PATH/usr/share/pixmaps/$EXE_FILE.png
        cp -f $INSTALL_PATH/usr/share/pixmaps/$EXE_FILE.png /usr/share/pixmaps/$EXE_FILE.png
        update_applications_menu
    function setup_online_update
        chmod 0755 $SYS_PATH/$FILE_NAME/$UPDATE_FILE
        cd $SYS_PATH/$FILE_NAME/usr/lib
        cp * /usr/lib
        if [ "$(cat /etc/lsb-release | grep Ubuntu)" != "" ];then
            if [ ! -L /usr/lib/libcurl.so.4 ];then
            ln -s /usr/lib/libcurl-gnutls.so.4.0.0 /usr/lib/libcurl.so.4
            fi
        elif [ "$(cat /etc/debian_version)"=="4.0" ];then
            ln -s /usr/lib/libcurl.so.3.0.0 /usr/lib/libcurl.so.4
            fi
        fi
    function copy_connection_files
        SYS_PPP_DIR="/etc/ppp"
        if [ -e $SYS_PPP_DIR -a -d $SYS_PPP_DIR ];then
            chmod a+x $SYS_PPP_DIR
        fi
        PEERS_DIR="/etc/ppp/peers"
        if [ -e $PEERS_DIR -a -d $PEERS_DIR ];then
            chmod a+x $PEERS_DIR
        fi
        chmod 0755 $INSTALL_PATH/pppd/ip-up.local
        cp -f  $INSTALL_PATH/pppd/ip-up.local /etc/ppp/ip-up.local
        chmod 0755 $INSTALL_PATH/pppd/ip-down.local
        cp -f $INSTALL_PATH/pppd/ip-down.local /etc/ppp/ip-down.local
        chmod 0755 $INSTALL_PATH/pppd/get_route_info
        cp -f $INSTALL_PATH/pppd/get_route_info /etc/ppp/get_route_info
        TMP_FILE=/etc/wvdial.conf
            chmod 0755 $TMP_FILE
        else
            cp -f $INSTALL_PATH/Data$TMP_FILE  $TMP_FILE
        fi
        TMP_FILE=/etc/ppp/options
        else
        fi
        TMP_FILE=/etc/ppp/resolv.conf
        else
        fi
        TMP_FILE=/etc/resolv.conf
        else
        fi
        #add by ChenYing 2009-3-5
        TMP_FILE=/etc/resolv.conf.bak
        fi
        TMP_FILE=/etc/resolv.conf.prev
        fi
        TMP_FILE=/etc/ppp/peers/wvdial
        else
        fi
    function copy_language_and_help_file
        echo > /dev/null
        #Language Select and help file
        #TMP_FILE=$INSTALL_PATH/bin/$LANGUAGE/$QM_NAME
        #if [ -f $TMP_FILE ];then
        #    chmod 0755 $TMP_FILE
        #    cp -f $TMP_FILE  $INSTALL_PATH/Data/$QM_NAME
        #fi
        #TMP_FILE=$INSTALL_PATH/bin/$LANGUAGE/$HELP
        #cp -r $TMP_FILE $INSTALL_PATH/Data
    function chmod_files
        chmod 0755 $INSTALL_PATH/bin/$EXE_FILE
        cp -f $INSTALL_PATH/bin/$EXE_FILE /bin/$EXE_FILE
        chmod 0755 /usr/bin/wvdial
        chmod 0755 /usr/sbin/pppd
        chmod 0755 $RUN_EVINCE
        chmod 0755 $APLAY   #added by ChenYing 2009-11-26
        chmod a+x $INSTALL_PATH/Data/run_evince.sh
        chmod 0777 $SYS_PATH
        chmod 0777 $INSTALL_PATH
        chown root.root $INSTALL_PATH/$EXE_FILE
        chmod 0755 $INSTALL_PATH/$EXE_FILE
        chmod u+s $INSTALL_PATH/$EXE_FILE
        chmod 0755 $INSTALL_PATH/uninstall.sh
    function setup_udev_rules
        TMP_FILE=$INSTALL_PATH/bin/9-cdrom.rules
        cp -f $TMP_FILE  /etc/udev/rules.d/9-cdrom.rules
        #if locate udevadm >/dev/null 2>&1
        if [ -f /sbin/udevadm ]
        then
            /sbin/udevadm control reload_rules >/dev/null 2>&1
            /sbin/udevadm control --reload-rules >/dev/null 2>&1
            /sbin/udevadm trigger --subsystem-match=block
            echo "udevadm is exist!"
        else
            /sbin/udevcontrol reload_rules
            /sbin/udevtrigger --subsystem-match=block
            echo "udevadm isn't exist!"
        fi
        rm -f  $INSTALL_PATH/bin/9-cdrom.rules
    function remove_temp_file
        rm -f $SYS_PATH/$FILE_NAME.tar.gz
    function install_driver
        echo ******Begin to $INSTALL_PATH/driver
        cd $INSTALL_PATH/driver
        chmod 0755  driver_uninstall.sh
        chmod 0755 driver_install.run
        ./driver_install.run
        echo ****** End to $INSTALL_PATH/driver
    function add_selinux_rules
        chmod 0755 se
        if [ -n "`uname -r |grep fc`" ];then
            ./se "/usr/sbin/semodule -i disselfirefox.pp"
            ./se "/usr/sbin/semodule -i nm.pp"
            echo "it's ok!"
        fi
    function change_user_group
        while read LINE
        do
            USER2CH=${LINE%%:*}
            LINE=${LINE#*:}
            LINE=${LINE#*:}
            USER_ID=${LINE%%:*}
            if [ $USER_ID -ge 1000 ];then
                if [ $USER2CH != "nobody" ]; then
                    #echo $USER2CH:$USER_ID
            if [ "OpenSUSE" == $(get_distro_name) ] ;then
                        /usr/sbin/usermod -G dialout $USER2CH
                else
                        /usr/sbin/usermod -a -G  netdev,dialout,dip $USER2CH
                fi
                fi
            fi
        done < /etc/passwd
    function setup_auto_start_script
        TMP_FILE=$INSTALL_PATH/launch-gui.sh
            chown root.root $TMP_FILE
            chmod u+s  $TMP_FILE
            cp -f $TMP_FILE  /bin
        fi
    #xinjunjie add
    #add by libing 2011-4-7
    function backup_file_of_Uninstallers
        TMP_FILE=/opt/Driver_Uninstallers
        if [ -d $TMP_FILE ];then
            cp -f $INSTALL_PATH/driver/driver_uninstall.sh $TMP_FILE
        else
            mkdir $TMP_FILE
        fi
    #xinjunjie end
    function handleXWindowProbOnOpenSUSE114
        export DISPLAY=":0.0"
        XUSER=`who | grep tty7 | awk '{print $1}'`
        if [ "" == "$XUSER" ];then
            XUSER=`who |  grep --regexp=:0[\ ] | awk '{print $1}'`
                    XUSER=`who |  grep --regexp=:0[\)] | awk '{print $1}'`
                fi
        fi
        echo $XUSER
        su $XUSER -c "xhost +"
    function run_program
        if [ $TWO_ON == 'true' -a $rettfp == '0' -a -f $LAST_RUN ];then
            chmod +x $LAST_RUN
            $LAST_RUN $RETURN_CHOOSE_LANG
        else
            echo "install completed!!!"
            echo  "....After setup, you will find the $DISPLAY_NAME in \"Applications->Internet->$DISPLAY_NAME\". Click the $DISPLAY_NAME and the application will run"
            read -p "press any key to continue.... " -n 1
            $EXE_FILE
        fi
    function update_applications_menu
        PARTIAL_NAME=$(locale | head -1)
        PARTIAL_NAME=${PARTIAL_NAME#*=}
        PARTIAL_NAME=${PARTIAL_NAME%.*}
        CACHE_NAME=`ls /usr/share/applications/desktop.*.cache | head -1`
        CACHE_NAME=${CACHE_NAME#*.}
        CACHE_NAME=${CACHE_NAME%.*}
        FILENAME=$PARTIAL_NAME.$CACHE_NAME
        if [ -f /usr/share/applications/desktop.$FILENAME.cache ]; then
            /usr/share/gnome-menus/update-gnome-menus-cache /usr/share/applications > /usr/share/applications/desktop.$FILENAME.cache
        fi
    # function defination end
    #main start
    echo "..................start install................."
    fi
    check_qt3
    check_wvdial
    echo "ok..."
    select_language
    setup_menu
    setup_online_update
    chmod_files
    setup_udev_rules
    remove_temp_file
    install_driver
    add_selinux_rules
    change_user_group
    run_program
    exit
    http://www.zte.co.nz/main/Product_Do..._downloads.htm
    30 47
: 1 (0 1 )
